Engine wiring for power ground / can bus diagram needed?
2017 HYUNDAI SANTA FE
1,467 MILES • 2.7L • 4WD • AUTOMATIC
ANDRIN ATEM
  • 393 POSTS
Car caught fire, so I bought a complete wiring from a junk yard, and it was badly cut, so if I can have this diagrams it will guide me to restore.
I appreciate all efforts by 2Carpros
SANTA FE SPORT / 2017/HYUN
5XYZTDLB4HG391081
Jun 24, 2025 at 10:11 AM
Sure, here is a guide to help with the testing and the CAN bus wiring system which shows the grounds.
Jun 25, 2025 at 11:08 AM
ANDRIN ATEM
  • 393 POSTS
May I also have the fuse box diagram and the ECU pin out diagrams.
Jun 26, 2025 at 3:34 AM
ANDRIN ATEM
  • 393 POSTS
Hi Ken, what I got from a junk yard is a 2017, sorry to I did not mention, but the car Santa Fe that had fire, is a 2013.
So, I need the ecu pin out for this 2017.
Engine fuse box diagram pinout
Thanks!
Jun 28, 2025 at 12:43 AM
I am sorry to hear that, fires are hard to repair. Here are the pin outs for the smart junction box, (fuse panel). Check out the images (below). Let us know how it goes.
Jun 28, 2025 at 10:36 AM
ANDRIN ATEM
  • 393 POSTS
Thank you Ken.
Jun 28, 2025 at 11:27 AM
ANDRIN ATEM
  • 393 POSTS
This has made all the difference, thank you so much.
Jun 28, 2025 at 11:58 AM
ANDRIN ATEM
  • 393 POSTS
Hi Ken, please may I also get the pinout diagram for the transmission connector, and gear switch range sensor.
For the engine, I think that will do. Will let you know how it goes.
Thank you so much.
Jun 28, 2025 at 12:00 PM
No problem, can you start a new thread? We only handle one problem per.
Jun 28, 2025 at 1:01 PM
ANDRIN ATEM
  • 393 POSTS
Sure! Thank you
Jun 28, 2025 at 2:23 PM
