Engine wire harness
2011 JEEP WRANGLER
187,000 MILES • 3.8L • 6 CYL • 4WD • AUTOMATIC
THOMCURTIS
I have mouse chewed, corroded butt splices, poorly repaired wear damaged wires. I understand that Chrysler used soy based wire insulation on the harnesses and the mice love it. I'm getting a variety of codes (mostly related to throttle control and gas pedal which both have been replaced to no avail), intermittent engine light, intermittent ABS light, intermittent traction control light. frankly I can't remember all the others. Several mechanics have been unable to isolate exactly what the issue or issues are. So I am wondering if it is a harness issue and where to get one.
Jun 19, 2019 at 4:20 AM
I would check the computer harness connections it sounds like it got put together incorrectly. Here is a guide to help you test and the engine wiring diagrams to help find the problem:
Jun 20, 2019 at 2:20 PM
