Engine wire harness
1996 HONDA ACCORD
174,508 MILES • 2.2L • 4 CYL • AUTOMATIC
AL FONS
  • 8 POSTS
To tell the truth I really do not because some connectors and sensors were mess up and now the car will not start up, it has power though out the car. The distributor is okay i guess that what some mechanics say.I just do not know what i did. It is a OBD2 harness. Can you please help me? Thank you for your time.
Apr 16, 2017 at 10:48 PM
HMAC300
  • 48,601 POSTS
something like this will need to be physically looked at and straightened out. plus scanned with a pro scanner to see if it is a security issue.
Apr 17, 2017 at 8:01 AM
AL FONS
  • 8 POSTS
So i just take this to a honda dealerships and see what they can do? How much $$$ would it cost me and how long?
Apr 17, 2017 at 11:37 PM
HMAC300
  • 48,601 POSTS
any garage can handle this not only a dealer. you'll have to check where you take it.
Apr 18, 2017 at 5:54 AM
AL FONS
  • 8 POSTS
Can i rebuild a harness from start to finish?And do you have a diagram of of the color wire's go and what they do???
Apr 18, 2017 at 6:21 AM
HMAC300
  • 48,601 POSTS
try American auto wire it's will probably be cheaper or get one out of ajunkyard with same engine/model as yours instead of trying to rebuild it.
Apr 18, 2017 at 6:59 AM
AL FONS
  • 8 POSTS
I also think the engine might be different from the car,does that make any different from the harness?
Apr 19, 2017 at 5:43 AM
HMAC300
  • 48,601 POSTS
if engine is a 4 cylinder and as long as connetors will match up it will run as the computer in the car. what this sounds like to me is you picked this up on the cheap hoping to fix the problems to either drive or resell. if you really plan on redoing this harness the easiest way is to put it back in and hook up connectors and see what you are missing etc.pic shows MOST sensors on engine not all
Apr 19, 2017 at 6:27 AM
AL FONS
  • 8 POSTS
Thank you for your time it's been a lot of help to me.Im not trying to sell it just wanted to clean it up and keep up with the car maintenance.So just to be on the safe side I should go down to the junkyard and pick up a harness accord today?How about the distributor?
Apr 19, 2017 at 6:58 AM
HMAC300
  • 48,601 POSTS
just make sure it's the same engine/trans ccmbo and everything else like a/c etc. distributor is up to you i'd scan it prior to doing an distributor.
Apr 19, 2017 at 9:46 AM
AL FONS
  • 8 POSTS
I've did what you said going to a junkyard and getting the samr set up but still no spark if i got every thing to a external coil and the car was internal coil would that make a difference???
May 22, 2017 at 3:55 AM
HMAC300
  • 48,601 POSTS
yes because one uses a dist the other doesn't
May 22, 2017 at 6:49 AM
AL FONS
  • 8 POSTS
The car hood reads OBD2 and the engine is F22B is there a problem?
May 29, 2017 at 8:18 PM
HMAC300
  • 48,601 POSTS
there shouldn't be that is what comes in that year as long as all your sensors hook up
May 30, 2017 at 5:17 AM
AL FONS
  • 8 POSTS
Because somebody said the engine is a older engine....i have a internal coil and it has 5 wires
May 30, 2017 at 8:18 PM
HMAC300
  • 48,601 POSTS
is there a s distributor or not if not then everything should hook up
May 31, 2017 at 6:32 AM
