Engine will not start
2003 MAZDA 6
129,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
URSULOROBLES
  • 47 POSTS
The car quit running will driving on road, approximately twenty five miles per hour. I had just put fuel at gas station. I checked for fuel pump operation, I can hear the electric pump come on and I add fuel to intake and still will not start. I noticed that spark is intermittent at spark plugs. It detonates and immediately shuts off and will not idle.
what should I check?
Nov 15, 2017 at 7:44 AM
If the check engine light has come on, check to see what trouble codes are stored in the computer. That will be a starting point for us. Let me know what you find. (Note: Intermittent spark may be the result of a bad crank sensor or wiring issue to the sensor)
Nov 15, 2017 at 8:33 PM
URSULOROBLES
  • 47 POSTS
I checked for trouble codes and it says, "no link". What shall I check?
Nov 16, 2017 at 2:14 PM
KHLOW2008
  • 41,814 POSTS
No link could mean a blown fuse, scan tool not compatible or a fault with the Engine Control Module.
I would suggest checking the fuses and if you have a test light, use it to check pin # 16 of OBD-II for battery voltage.
Nov 18, 2017 at 6:59 AM
URSULOROBLES
  • 47 POSTS
Where is the OBD11 computer? thanks,
Nov 18, 2017 at 7:49 AM
The OBD port is under the dash on the driver's side of the vehicle. It's not the actual computer, but rather the port were you attach the scanner.
Nov 19, 2017 at 5:58 PM
URSULOROBLES
  • 47 POSTS
You want me to check pin 16 on obd11 connector for voltage? Can you give me a pic of which is pin16?
Nov 20, 2017 at 6:22 AM
URSULOROBLES
  • 47 POSTS
Ok, I saw two pins on the OBD11 connector, with key on, the pin connector on the right, looking straight at connector, has a dim light, not bright like the brightness on a fuse. Let me know, thanka,
Nov 20, 2017 at 5:59 PM
KHLOW2008
  • 41,814 POSTS
The connector has 2 rows of 8 pins with some pins empty. It should be the last one on the right. What did you use to get the light?
Nov 23, 2017 at 6:39 AM
URSULOROBLES
  • 47 POSTS
Facing the connector, the pin on right has 2.5 volts with key on
Dec 13, 2017 at 1:59 PM
KHLOW2008
  • 41,814 POSTS
I am not sure if you are showing the correct pin. What you mentioned could be Pin # 1 or Pin # 16 as they are diagonally opposite. The color of the wire should be Blue/Red (blue with a red stripe) and it gets its power from Room fuse (15 A). Is the room light light working?
Dec 15, 2017 at 7:26 AM
