Engine vibration and ticking?
2001 JAGUAR VANDEN PLAS
123,000 MILES • V8 • 2WD • AUTOMATIC
GFRIEND
  • 4 POSTS
The radiator hose became disconnected in the car overheated. After repairing the hose, the car now has a vibration from the engine and a ticking noise coming from the valve area. Help
Mar 26, 2023 at 2:11 PM
Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response. It might be you have a broken valve spring are the engine got too hot and you have low compression on one or more cylinders, or the head gasket is blown.
Here is a guide that you can go over for more information:
and
https://www.2carpros.com/articles/recognizing-the-symptoms-understanding-a-blown-head-gasket-in-your-vehicle
Please go over these guides and report back.
Mar 27, 2023 at 8:34 AM
GFRIEND
  • 4 POSTS
Here’s the video.
Mar 27, 2023 at 9:22 AM
Thanks for the video. which is a nice car, sorry about your troubles, it does seem like the engine is hurt, like a head gasket is blown between two cylinders, which is common when overheated. To confirm the problem, we need to do a compression test. This guide can help and show you which side the gasket is blown on, if so, I would do both gaskets since the engine will be apart.
If you would like to do the job yourself let us know and I will give you instructions. Please let me know how the test comes out.
Mar 27, 2023 at 12:47 PM
GFRIEND
  • 4 POSTS
Compression test showed no compression in no. 8 cylinder. On week before the problem, the mechanic said he could smell antifreeze in exhaust. Worth digging into?
May 10, 2023 at 4:51 PM
That is up to you, the engine will need to be disassembled to see what the problem is. Please let us know what you find.
May 11, 2023 at 9:30 AM
