Engine vibration?
2008 CHEVROLET AVEO
179,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
RPJ
  • 97 POSTS
I have noticed a leak from the radiator cooler lines. This has happened before, and I think it is due to engine vibration when the car is idling in traffic.
I'm thinking it may need fuel injection service since it has been a few years since this has been done.
What do you think?
Thanks, Roosevelt.
Feb 18, 2025 at 7:13 PM
CANNON1349
  • 861 POSTS
If you suspect there is too much vibration, you may want to check the engine mounts. Sometimes this can be done by putting the vehicle in drive while the left foot is on the brake and using the right foot to quickly throttle the engine, you may hear a knocking or feel a big vibration if the mounts are worn out.
About a fuel injection service, it does depend on the type of service. If you are referring to a fuel system cleaning of the valves, the typical mileage interval the general shops give is around every 20,000 miles for modern engines. The parts stores also sell a fuel injection cleaner to put in the gas tank that is also beneficial and is also usually given during a service.
Hope this helps,
William
Feb 18, 2025 at 7:31 PM
RPJ
  • 97 POSTS
Thank you very much for the quick reply. I will check this and let you know the results.
Roosevelt.
Feb 18, 2025 at 7:54 PM
CANNON1349
  • 861 POSTS
Sounds good. Please let us know!
William
Feb 18, 2025 at 8:07 PM
RPJ
  • 97 POSTS
I did the "check" for the engine mounts and did not feel the vibration that you mentioned. I will have the vehicle serviced for a routine oil change and fuel injection service.
I will keep you informed on what happens next.
Thanks again for your help.
Roosevelt.
Feb 22, 2025 at 9:34 AM
CANNON1349
  • 861 POSTS
Hello, thanks for the update!
That "Check" will make a broken motor mount show itself, however a cracked or torn mount that is still holding the engine may be found by the technician. If they mention this, do ask for pictures. Please let us know how it turns out!
William
Feb 22, 2025 at 9:36 AM
RPJ
  • 97 POSTS
The shop replaced the three motor mounts on the vehicle along with the FI service and the car runs as smooth as silk. I am amazed that a 17 year old vehicle is running so smoothly and quietly, almost the way it was when I purchased it new.
The belt tensioner pulley was replaced also along with the belt.
Thanks for your advice on the mounts, it made all the difference.
Roosevelt.
Feb 26, 2025 at 6:51 PM
CANNON1349
  • 861 POSTS
I am happy to hear about the repair! It was a pleasure to assist you, and thank you for using 2Carpros.
William
Feb 26, 2025 at 8:02 PM
