Good morning,
This sounds like motor mounts that are worn out.
https://www.2carpros.com/articles/vibration-noise
https://www.2carpros.com/articles/how-a-motor-mount-works
https://www.2carpros.com/articles/replace-motor-mounts
Removal and Installation
Remove the 2 expansion tank bolts.
To install, tighten to 4 Nm (35 lb-in).
Lift the coolant expansion tank off of the engine mount stud bolt and position it aside.
Install the Engine Support Bar.
Remove the 2 engine mount nuts.
To install, tighten to 90 Nm (66 lb-ft).
Remove the 2 bolts, stud bolt and the engine mount.
To install, tighten to 48 Nm (35 lb-ft).
To install, reverse the removal procedure.
Jan 24, 2021 at 5:17 AM
