Engine vibration
2005 SATURN ION
190,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
JASON DAVIS
The car is shaking and the wheels feel like they may fall off.
Jan 15, 2019 at 4:53 PM
Hi and thanks for using 2carpros.com.
First, confirm there are no tire issues. Check for cupped tire tread. Next, you should have the tire balance checked. That can cause a vibration. Also, check if a wheel is bent, damaged, or has picked up mud or dirt which is sticking on the wheel. Here is a link that shows the different ways tires can wear.
https://www.2carpros.com/articles/how-car-tires-work
Now, I am basing this in the vehicle shakes when moving. If there is a different issue, let me know. Also, let me know if there are any noises like a humming or rattling. There could also be an issue with alignment or a steering component. Those should show tire wear issues.
Let me know if this helps.
Jan 15, 2019 at 6:36 PM
