Okay. That is great info but a couple more questions to narrow this down.
When you are feeling this, does it go away as soon as you remove the accelerator? Can you feel it in the seat or in the steering wheel?
If you only feel this vibration at higher speeds and when you are accelerating, that sounds more like a drive train issue like a CV axle.
However, we do need to eliminate all the things you mentioned.
So we need to pull the spark plugs out and inspect them. Then we need to check the fuel pressure when this is happening.
Here are guides that will help with this:
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Below is a chart of possible issues with the plugs. Let's take a look at them and the fuel pressure and go from there. Thanks
May 20, 2021 at 9:38 AM
