Engine/transmission
2003 ACURA TL
121,300 MILES • 6 CYL • 2WD • AUTOMATIC
DJMARIE
  • 21 POSTS
Gears shifting from second to third really it seems to get stuck almost in gear and then almost jerks the car when engaging into gear.please can you give me any suggestions? No codes came up to read when I had it in shop and they said it should run smoother once I have transmission flushed?
May 24, 2016 at 12:52 PM
If there are no codes, there is a good chance servicing it with the correct fluid and even a quality additive may help. Have you had the work done yet?
May 24, 2016 at 6:52 PM
MAXIMILIAM
  • 436 POSTS
I haven't yet had transmission flushed, but will. Thanks again
Dana
May 24, 2016 at 10:39 PM
