Slow acceleration
1991 NISSAN BLUEBIRD
200,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
MATTMC787
Having problems or slow acceleration.
Apr 29, 2018 at 3:57 AM
Good morning.
First thing to check on low power complaints is the filters. Fuel and air are the most important.
Check the compression as well. low compression from a worn engine or timing would cause this.
Fuel pressure needs to be checked as well. not enough fuel will cause this issue.
Lastly, a clogged exhaust system will also cause this issue.
Apr 29, 2018 at 6:27 AM
