Engine ticking
2015 DODGE CHARGER
124,200 MILES • 3.6L • V6 • 2WD • AUTOMATIC
MOPARKID08
There is a ticking noise coming from the engine while being idle/driving. I am not sure why this is happening and what is the proper fix for this? And code p0430 - catalyst system efficiency below threshold (bank 2).
May 3, 2018 at 11:03 PM
The code and noise can be related. If the catalytic converter has fallen apart inside it will make a rattling sounds and make the code. Here is a guide to help you confirm the failure:
but is could be the engine too here is a guide to help
https://www.2carpros.com/articles/comprehensive-guide-to-identify-and-fix-ticking-and-tapping-noises-in-engines
Can you please shoot a quick video with your phone so I can hear the noise? that way I can tell for sure what's going on.. You can upload it here with your response.
May 6, 2018 at 12:43 PM
