Engine temperature warning light turned on?
2014 CITROEN PICASSO
28,000 MILES • 1.6L • 2WD • MANUAL
MARTIN WEINTHROP
This red warning light came on suddenly yesterday, telling me to stop driving. I was only a road away from home, so i left the car engine to cool, and later added some extra coolant and engine oil - although their levels were NOT low. I've tried it again this morning, the car having been overnight in the garage, and even though I just start the engine, the light comes on and suggests it is over-heating, which is impossible as the engine is stone cold.
I can find no leaks or problems with anything else and suspect it may be a sensor that has failed. Any ideas? Is it safe to drive it to a local garage?
Thanks, Martin
Sep 26, 2024 at 8:43 AM
This vehicle isn't offered in the US, so my manuals don't provide me with information. However, I will try my best to help.
Based on what you indicated, the first suspect is the engine coolant temperature sensor is faulty or there is a wiring issue most likely at the sensor connector.
Are you able to locate the sensor? Often times it will be near where the coolant thermostat is located.
joe
Sep 26, 2024 at 3:08 PM
Yep, you are correct, if the engine coolant sensor goes bad it will tell the computer the engine is hot all the time, I would get a replacement coolant sensor and replace it. This should fix the problem. Let us know how it goes.
Sep 26, 2024 at 3:24 PM
MARTIN WEINTHROP
Thanks, Ken and Joe. I'm not very technical so will have to get an expert to look at it, but logic suggests if it is not actually over-heating then it's possibly the sensor. In which case it should be okay to drive to a garage without causing more damage, right?
Sep 26, 2024 at 11:54 PM
You should be okay, but if the engine seems hot while driving stop because there is no way to tell what the temperature is. Make sure it is full of coolant.
This video can help:
https://youtu.be/GSE9skKnOgY?si=qOzCWVFYkoZszVpK
Sep 27, 2024 at 10:55 AM
