engine temp going high ,coolent overflow in coolent tank
2002 NISSAN SUNNY
314,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
GBHATTA73
  • 5 POSTS
I already disscussed to you, there is no leakage in cooleny.but after i going in 100 speed coolent going to coolent tank and over flowed,due to overflow coolent level reduced in radiator so engine temp. going high,already i changed pump and radiator with mechanic, finaly he dout in engine gasket, but engine run smoothly, please tell me what this problems.
Nov 30, 2014 at 2:18 AM
WRENCHTECH
  • 20,761 POSTS
If you already have a question started, then you need to respond to your original question. That way the original expert will be notified and continuity of the problem will be maintained.
Nov 30, 2014 at 4:38 AM
