Engine tapping noise
2002 FORD MUSTANG
232,000 MILES • 3.8L • V6 • 2WD • MANUAL
MUSTANG OLIVER
My car makes a tapping noise. If I start it when it's cold out side then there isn't any noise. But once it's slightly warmed up just a little bit it makes a terrible tapping noise while sitting at an idle. If I slightly push on the throttle the tapping rate increases with the RPM's but then completely goes away once it's at 1k RPM's.
Dec 1, 2019 at 6:29 PM
CJ MEDEVAC
  • 11,004 POSTS
Your mileage may reflect a good bit of wear, on every part of the valve train!
Maybe your Tappets (lifters) are not operating as they should, because of goop/carbon buildup/anything similar you might try this:
Do an oil change, substitute 1 qt. of Marvel Mystery Oil for 1 qt of motor oil. This will clean and free up the internals of your tappets.
Tappets readjust to zero for the push rods (all involved parts)slack/ slop/ wear (every time they drop down into oil pressure in the oil galley, that they ride in). They open and refill and take-up any slack. Upon raising up they Close off and function much like a hydraulic jack, oil has refilled the slack void that was there when they traveled downward.
.Unless "crap" prevents the tappets from sealing off to act kind of like a hydraulic jack. This is referred to as a leaking tappet/lifter The Marvel Mystery Oil may clean them up and fix the leaking issue!
You can run it until the next oil change oil change w/Marvel Mystery Oil. (It can be run every oil change if you want). I usually do it once to clean my tappets on one oil change. I use an oil stabilizer (such as Hi-Tach or Lucas) substitute it for a qt. of oil during all future oil changes.
Pic below, see the many parts crammed in such a small container?
You may be able to clean them up with the Marvel Mystery Oil. Missing those oil changes does not help!
Keep us posted.
The Medic
Dec 1, 2019 at 7:30 PM
