Engine swap issues
1998 CHEVROLET 1500
134,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
ABRATTON623
  • 4 POSTS
I pulled a 5.7l from a 1997 k1500 that ran great and put it in my 1998 k1500. Everything lines up, but the issue I have is the starter is not engaging the flywheel and just clicks. It has a new battery and new starter in it. And the engine is now seized. Any clues?
Jun 9, 2020 at 4:51 AM
Good morning,
Do you mean the gear on the end of the starter is stuck on the flywheel?
Did you change the flywheel during the swap? Which flywheel is on the motor?
Jun 9, 2020 at 7:32 AM
ABRATTON623
  • 4 POSTS
I didn't change the flywheel and the gear isn't lining up with the starter gear to crank the engine.
Jun 9, 2020 at 8:38 AM
ABRATTON623
  • 4 POSTS
I have a typo in the main message, it is not seized. It moves freely.
Jun 9, 2020 at 8:40 AM
It sounds like you need to shim the starter to get it to engage the flywheel gear.
Were there any shims in the starter box when you got it?
Jun 9, 2020 at 8:48 AM
ABRATTON623
  • 4 POSTS
No.
Jun 9, 2020 at 9:40 AM
You can go to a parts store and get the shims.
Is the starter from the donor engine? If it ran great in the other truck, you should not have any issues with it now.
Jun 9, 2020 at 10:31 AM
