Engine swap
1998 GMC SONOMA
191,500 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
KMANN21B
Engine locked up. Was wondering if a 2.2 off a 1998 Cavalier would work?
Dec 22, 2017 at 1:28 AM
Good morning my name is Roy and I will assist.
You need to look at the block of the Cavalier and make sure the bosses are there for the motor mounts and they are drilled. If they are then yes. You will need to strip down the motor from the cavalier to a long block and then remove all the parts from your truck to the donor motor. then you can install it.
Dec 22, 2017 at 3:06 AM
