Engine swap
2006 CHEVROLET IMPALA
217,735 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
IKEAWAL
Can I put a 5.7 l engine into my 2006 Impala ls? and if so what will I need to do it ?
May 22, 2019 at 8:14 PM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
It is possible to do the swap however it would be a very difficult to do and have it emissions legal. One factor you need to consider is that the engine has to be the same model year or newer, you also should consider that you would need to change transmissions, wiring harness, computer, radiator, front springs and I'm sure you would run into other issues. My suggestion would be if you want to build a high performance version of that model car is to find a 5.3 version and then look into installing the 5.7.
May 24, 2019 at 4:12 AM
