If none of them are working, something is disconnected, we have a ground issue (unlikely), or a blown fuse.
________________________
Here are the diagnostics for no gauges working. The attached pics are the actual diagnostics.
2002 Dodge or Ram Truck RAM 1500 Truck 2WD V8-4.7L VIN N
All Gauges Inoperative
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Testing and Inspection Manufacturer Code Charts Instrument Cluster All Gauges Inoperative
ALL GAUGES INOPERATIVE
Tests 1 - 3
Pic 1
Tests 4 - 7
Pic 2
Test 8
Pic 3
SYMPTOM
POSSIBLE CAUSES
- No response - PCI BUS
- PCI Bus - powertrain control module
- PCI Bus - instrument cluster
- Fused ignition switch output circuit (unlock/run) short to ground
- Instrument cluster ground circuit open
- Fused ignition switch output (run/start) circuit open
- Fused ignition switch output (run/start) circuit short to ground
- Fused ignition switch output (unlock/run) circuit open
Let me know if that helps.
Nov 19, 2020 at 6:36 PM
