Understandably so, however, Just having that sucked in doesn't clean both sides and all around the throttle plate. Especially in the edges where it pivots. If you are not familiar in how to use the product then you can cause cylinder damage with a lot of spark knock. You can also spray around the intake with the cleaner to check for any vacuum leaks.
Feb 9, 2016 at 6:41 AM
