Engine surge
2003 CADILLAC CTS
1,200 MILES • 3.2L • V6 • FWD • AUTOMATIC
STROZIER
My engine will surge only in idle.
Feb 1, 2016 at 4:09 AM
JOHNNYT73
  • 924 POSTS
I would get a can of throttle body cleaner and clean out the throttle body. Be sure to get both side of the throttle plate.
Feb 1, 2016 at 4:41 AM
JOHNNYT73
  • 924 POSTS
Understandably so, however, Just having that sucked in doesn't clean both sides and all around the throttle plate. Especially in the edges where it pivots. If you are not familiar in how to use the product then you can cause cylinder damage with a lot of spark knock. You can also spray around the intake with the cleaner to check for any vacuum leaks.
Feb 9, 2016 at 6:41 AM
STROZIER
I think it just might be a vacuum leak, it's still surging in idle as usual.
Feb 12, 2016 at 8:17 AM
JOHNNYT73
  • 924 POSTS
You will usually get smoke out of the tailpipe. It's the carbon being washed off and burned.
Feb 12, 2016 at 8:23 AM
STROZIER
No car in came from my tailpipe at all, what does this mean?
Feb 16, 2016 at 6:49 AM
I think you are on the right tack when you said it was a vacuum leak, here is a guide to help find it,
Let me know what you find
Apr 23, 2016 at 7:35 PM
