Engine support
2013 FORD FIESTA
59,870 MILES • 1.6L • 4 CYL • AUTOMATIC
MARLENE009
How many engine support or mount it has? I've been searching on many internet sites and owner manual can't figure it out.
Nov 6, 2019 at 4:41 AM
BMDOUBLE
  • 1,139 POSTS
The main supports are on the front and the rear transmission mount, the mount on the front of the sub-frame is for torque and not weight, so 3 mounts. Here are pictures from the repair manual:
Nov 6, 2019 at 8:03 AM
MARLENE009
Thank you. I appreciate your help.
Should I replace all of the or just the broken one?
Nov 6, 2019 at 8:46 AM
MASTERWRENCH
  • 258 POSTS
Typically you only replace the ones that are broken. However, I would inspect the others for signs of wear or cracking. If you find any of this, it would be a good a idea to replace those as well.
Nov 9, 2019 at 7:43 AM
