Engine stutters after warm up
2005 BUICK RANIER
217,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
DASCON
  • 10 POSTS
This is a repost due to my error of being the first to reply to my own question as I was attempting to amend my initial question.
A 2CARPROS expert suggested that I re-post my question to get a more informed reply.
Thanks Caradiodoc!
Prior to engine getting to operating temperature the engine runs normally.
After fifteen minutes of continuous operation the engine is at temperature and will sporadically stutter while cruising around 2500 to 3000 rpm's (fifty to fifty five mph). Occasionally, when at a stop light (idling) the engine rpm will drop to below 500 and may or may not stall. If it does not stall, then it will hunt between 300 to 800 rpm's. Once this symptom begins it may last for as little as thirty seconds to as long as fifteen minutes. While at a stop light I can keep the engine from stalling by holding the brake pedal with my left foot and gently pressing the accelerator to maintain the rpm above 750 while it continues to hunt.
I monitored the front and rear O2 sensors during operation and observed the following:
When the engine is operating normally the O2 sensors are reading as expected. The front O2 voltage swings up and down. The rear O2 voltage maintains around 0.7 volts.
When the engine is in a fault condition the front O2 voltage will drop to 0.45 volts and hold (+/-.02) for the duration of the fault.
The rear O2 will drop to 0 volts and occasionally raise to 1.0 volts then back to 0 volts for the duration of the fault.
When the engine returns to normal operation the O2 sensors return to normal values.
There were numerous trouble codes:
P0134
P0133
P0171
P0420
P0442
P0130
P1133
I cleared the codes to start anew.
I have taken two test drives exceeding thirty minutes since clearing the codes. Both test drives experienced the fault condition but, set no codes.
If I turn off the engine during the fault condition and exit the vehicle, I can smell a lean fuel condition.
My instinct is the car is entering an EVAP purge and there may be a vacuum leak.
I am hoping someone can give me a focused direction to investigate and/or what data to monitor using my ODBII (live data) device.
Thanks,
Carl
Dec 20, 2017 at 7:43 PM
DASCON
  • 10 POSTS
After the engine is at temperature the engine will sporadically stutter while cruising around 2500 to 3000 rpm's (fifty to fifty five mph). Occasionally, when at a stop light (idling) the engine rpm will drop to below 500 and may or may not stall. If it does not stall, then it will hunt between 300 to 800 rpm's. Once this symptom begins it will last for thirty seconds to one minute. While at a stop light I can keep the engine from stalling by holding the brake pedal with my left foot and gently pressing the accelerator to maintain the rpm above 750 while it continues to hunt.
When the engine is operating normally the O2 sensors are reading as expected. The front O2 voltage swings up and down. The rear O2 voltage maintains around .7 volts.
When the engine is hunting then the front O2 voltage will drop to a low voltage and hold for a few seconds (I do not recall the value) then raise to a high value and hold for a few seconds then repeat.
The rear O2 will drop to 0 volts for a few seconds then raise to a high voltage for a few seconds.
The front O2 and rear O2 values swing independently of each other.
P0134
P0133
P0171
P0420
P0442
P0130
P1133
On my first test drive after clearing the codes the engine stuttered after achieving operating temperature and I received data indicating the fuel was lean. No codes were set.
Thanks,
Carl
Dec 21, 2017 at 3:03 PM (Merged)
DASCON
  • 10 POSTS
I have an update with better detail.
i just finished a thirty minute test drive.
The engine performed normally for the first fifteen minutes.
While I was driving through town; stop and go, the engine began to stall at a stop sign. The front O2 indicated a constant 0.45 volts. The rear O2 indicated a constant 0.0 volts. The vehicle maintained these values for several minutes as I continued to drive through town. I had to hold the accelerator slightly while at stop signs or the engine would die.
When I exited town and got the rpm's above 3000 the rear sensor read 1.0 volts. The front O2 would fluctuate some but, for 95% of the time it indicated .45volts +/-.02 while the rear O2 would indicate either 1.0 or 0.0 volts. The vehicle continued in this manner until I ended the test drive.
A trouble code never appeared.
As I think about my initial description and this description, I must amend my initial to reflect that the front O2 sensor did not fluctuate during the problem condition but, instead held a constant .45 volts as it did during my last test drive.
CARADIODOC
  • 34,306 POSTS
Hi DASCON. Dandy descriptions and thank you for listing the engine size and mileage. Unlike other sites where anyone can chime in, here this becomes a private conversation between you and one or two experts. When you posted the follow-up, it moved your question to our list of questions that have already received replies. That makes it look like you are in a continuing conversation already, and most of us will not butt in. Most of the other experts will not see it or have a chance to reply. That will not get you the help you need. I only read it thinking I might learn something.
I can add a few comments of value, but consider reposting your question so it shows up as a new one waiting for an answer. Engine performance is not one of my specialty areas.
Contrary to common belief, oxygen sensors typically will not cause such noticeable running problems, but their readings do indicate the results of those running problems. Look instead at the other sensor readings to see what the engine computer is responding to. One in particular is what the computer is requesting for idle speed. If you see "idle steps" or "throttle percentage" go up when idle speed goes down, the computer is trying to raise idle speed but without success. Years ago, when fuel additives were not so effective, we saw a lot of air passages around the throttle blades plugged with carbon. That prevented proper operation of the idle air control valve.
If you see the requested idle speed go up when actual engine speed goes up, the computer is asking for that in response to something. Check if the intake air temperature sensor and coolant temperature sensor are reading correctly. Temperature sensors have a very low failure rate because there's just one component inside them. More problems are caused by resistance from corrosion between mating terminals in a connector and adjacent terminals in a connector.
Chrysler is the only manufacturer that never needed a mass air flow sensor to make their engines run right. For all other brands, that sensor is the main fuel metering calculation. There cannot be any leaks in the fresh air tube between the mass air flow sensor and throttle body. Vacuum leaks cause the same problems. If any air sneaks in that does not go through the mass air flow sensor, no fuel will be calculated to go with it.
GM makes a lot of use of knock sensors. At the mileage you listed, it is possible the timing chain is sloppy and is slapping against the cover. The knock sensor will detect that as spark knock and the engine computer will retard ignition timing to try to stop that. Look at the requested timing on the scanner to see if it is bouncing around.
There seems to be a lot of performance problems solved on GM vehicles by attending to ground wire connections. Computers usually have multiple ground wires and they are for different circuits. Do not waste your time trying to measure resistance in those wires and connections. It will be far smaller than the normal resistance of your meter leads, even when it is excessive. Instead, measure the voltage on those wires while the systems are in operation. A resistance that is too small to be measured will cause a voltage drop that can be measured.
DASCON
  • 10 POSTS
Thank you Caradiodoc for you quick and very informative response. I will do as you suggested and repost my problem condition. In the mean time i have a follow up for you.
The conditions that you described appear to be associated with continuous conditions. Would they apply to a situation like mine where the engine runs fine for the first fifteen minutes then like throwing a switch the fault occurs. Although, my fault condition continued until the end of my test drive; in prior drives the fault would clear after about five to ten minutes. especially if I turned the engine off for ten or more minutes.
CARADIODOC
  • 34,306 POSTS
Watch on your scanner to see if it shows whether the system goes into closed loop or stays in open loop. The coolant has to reach a specific temperature, then the computer switches to closed loop. The only difference is in open loop, the oxygen sensor readings are ignored. Those sensors have to reach 600 degrees before they start to work and the assumption is they reach that by the time the coolant is warmed up. The computer calculates fuel needs based on all the other sensor readings, with the mass air flow sensor being the major contributor. In closed loop, the front O2 sensor reading is just used to fine-tune the average mixture. The rear sensor is only used to monitor how well the catalytic converter is doing its job. That one has nothing to do with engine performance.
You can also look at fuel trim numbers to see how much the computer needs to vary the fuel metering calculations from those that are pre-programmed in at the factory. High positive numbers means it feels the need to add more fuel than expected. That could be, for example, in response to a vacuum leak. High negative numbers means too much fuel is going into the engine and the computer is trying to reduce that amount. Causes can include a badly-leaking injector or fuel pressure that is too high. A spark-related misfire will send too much unburned fuel into the exhaust system, but that should be detected as a "specific cylinder misfire" or a "random cylinder misfire".
DASCON
  • 10 POSTS
I will concentrate on the connections surrounding the mass air flow as well as monitor the open/closed loop condition.
My earlier fixation on the O2 sensors is due my lack of knowledge and they were the only indicators that I knew of that would give me an indication that I should anticipate trouble at my next stop light.
You have given me additional sensors to monitor that will be helpful. Thanks!
Dec 21, 2017 at 3:04 PM (Merged)
CARADIODOC
  • 34,306 POSTS
As Paul Harvey used to say, "I told you more than I know". I can do a real good job of explaining theory of operation, and I can share stories I have heard and read about, but the real specialists can find clues in minute sensor reading changes the rest of us would overlook. Some of the people here are real good at analyzing all kinds of sensor data and they have tricks to force artificial lean and rich conditions to see how the computer responds. That is why it was in your best interest to re-post your question. I will keep an eye on your new question to see who replies. I have two or three people in mind already.
DASCON
  • 10 POSTS
I think your recommendation to watch the coolant temperature may have sent me down the proper path. I watched it before and noted 180-185F but, I assumed that was the proper temperature. Today's test drive set a code P0128 - low coolant temperature. After some research I determined the operating temperature should be 205 - 210F.
I do not have an option to monitor open/closed loop directly (at least I cannot figure out where the setting is located). I did notice that a set of onboard tests could no be performed due to the system staying in an open loop.
I intend to change the thermostat. More research indicates that I need to clear my calendar for a few hours, ugh.
At 217,000 miles, I think a close visual inspection of the mass flow sensor may pay a few dividends also.
I will let you know what transpires.
RENEE L
  • 1,260 POSTS
Hi DASCON,
I have reopened this question in the cue for another expert to answer.
Renee
Dec 21, 2017 at 3:14 PM
DASCON
  • 10 POSTS
Thank you Renee for your intervention. I hope this posting this doesn't undo your action. Although, I think my issue has been resolved due in large part to Caradiodoc's guidance.
Prior to today I would never had thought that the engine temperature could have such a detrimental affect on the performance of the engine.
My coolant temperature was steady at 185F. My ignorance and "Old School" mechanical knowledge of the '70s lead me to believe that 185F was an appropriate operating temperature. That, along with never receiving a code denoting anything to indicate otherwise.
As fate would have it, one day after Caradiodoc suggested verifying the coolant temperature, along with many other suggestions, my vehicle set the P0128 code - Low Coolant Temperature during a test drive.
I researched and learned three important facts.
1) The thermostat is a common contributor to this code.
2) The operating temperature should be between 200-210F.
3) Changing the thermostat is not a 30 minute task.
After spending 4 hours replacing the thermostat I can report that my vehicle is running as designed with no stuttering or stalling. It now operates at 199-201F.
In my world of modern automotive ignorance it is difficult for me to get my mind around the fact that 15F can have such an impact on performance.
I'm told that a proper diagnosis is 80% of the work. In my case...Amen Brother! I spent weeks trying to figure this out.
I hope others can learn from my experience.
Thanks Caradiodoc!!!
Dec 21, 2017 at 8:58 PM
STEVE W.
  • 15,113 POSTS
Well it seems I'm late to the party, story of my life.... Low coolant temps cause the PCM to keep sending extra fuel because the engine is running "cold". However I've never seen it cause the type of symptom you posted earlier, like an on/off switch causing the O2 sensors to drop out.
I have seen that before though. It was due to the wiring harness at the rear of the engine rubbing through at the corner of the engine and the O2 signal wires getting shorted to the block. It only acted up when the engine would warm up because the wire insulation would get softer. The harness T's off at the back to come over the top of the engine and carries a couple sensor wires and wiring to the alternator. If you replaced the thermostat you may have moved that harness enough to fix the issue. I would check the harness to be sure that wasn't the reason for the O2 related items. It's nothing some liquid tape and wrapping the area with some good Etape won't fix if the wiring id damaged.
Either way, you did a good diagnosis on the T-Stat.
Dec 22, 2017 at 6:51 AM
DASCON
  • 10 POSTS
Welcome to the party Steve. I don't think it's over.
It seems that I was lulled into a false state of bliss and my enthusiasm was short lived.
The same symptoms returned today and I have additional detail to provide.
I planned a test drive that separated highway cruising from low speed city.
I monitored 6 sensors during my drive:
Coolant Temp
Voltage
Long Term Fuel Trim
Short Term Fuel Trim
O2 1-1
O2 1-2
The Coolant Temp and the Voltage never deviated from normal indication regardless of fault condition and those values were 198-201F and 14.4-14.6 respectively.
During normal operation the sensors indicated the following:
Long Term Fuel Trim varied slightly 0% - +3%
Short Term Fuel Trim varied more frequently (-)2% - +5% (Mostly
Dec 23, 2017 at 12:42 PM
DASCON
  • 10 POSTS
uh oh... is there a character limit to a post?
Half of my post did not appear.
Dec 23, 2017 at 12:45 PM
DASCON
  • 10 POSTS
Continuation...
Short Term Fuel Trim varied more frequently (-)2% - +5% (Mostly 2%)
O2 1-1 Fluctuating random values from .1 - 1.1 volts
O2 1-2 A steady .7 volts
For approximately 45 minutes I drove a steady 1800 RPM (~60 MPH) and the engine operated as designed.
I then drove through the city with stop-and-go traffic. A code of P0420 Catalyst Below Threshold. There were no indicators that anything was wrong. The gauges read normal and the engine ran smoothly; just the Check Engine light. I stopped the car and cleared the code so the Check Engine light would be off. i continued driving for about 10 minutes. While at a stop sign i noticed the gauges appeared to "freeze".
The values were:
Long Term Fuel Trim I don't recall but. i think around 2%
Short Term Fuel Trim I don't recall but. i think around 2% also
O2 1-1 A steady .45 volts
O2 1-2 A steady 0.0 volts
i noticed the Short Term Fuel Trim drop to -19.2% and the engine began to stall. As I accelerated the value change to positive and the engine gained power. I left town and maintained a steady ~1500 RPM (45 MPH). During this time I noticed the gauges, for the most part, would stay "frozen" and occasionally one or more would change values and freeze again.
I noticed the Short Term Fuel Trim would consistently indicate -19.2% or +19.2%. When displaying a negative value the engine would lose power.
I noticed the O2 1-1 would rarely leave .45and would always return to .45.
I noticed the O2 1-2 would rarely leave 0.0 and when it did it would go to 1.0.
I noticed the Long Term Fuel Trim would occasionally read approximately +12% and sometimes go negative.
After about 10 minutes everything reverted back to normal.
I am leaning towards what Steve W. suggested that there may be a damaged wire which may be acerbated by heat or maybe a poor ground as suggested by Caradiodoc.
The engine has been running better since I changed the thermostat which leads me to believe that I may have manipulated a wiring harness just enough to improve a poor connection yet not repair it.
*NOTE* When I changed my thermostat I did not remove the alternator. I went through the wheel well to access the bolts. During this action I unmounted the ECM ( I kept the wiring intact) and I manhandled the wiring harness.
I'm back on the 80% side of the fence looking for a proper diagnosis.
Bad ground - where do i look?
Bad ECM - how do I test?
Poor wiring harness connection - ugh...
Open vs closed loop - I do not know how to check this status. I am using a simple tool called OBDLink which connect to my phone via Bluetooth.
Can anyone give me direction? Just a slight push
Any Expert live near St. Louis where I can drop off the car along with some $'s?
I am close to searching Google Maps for the nearest cliff.
Dec 23, 2017 at 1:36 PM
STEVE W.
  • 15,113 POSTS
Not that I know of, I've posted half a book before and it all showed up. Take a close look at the wiring around the rear of the engine and down to the sensors, if they are shorting it can cause a lot of problems with the exact symptoms you are having. The O2 sensors shorting causes the ECM to go nuts, especially if they toggle in/out with different values every time.
Dec 23, 2017 at 1:42 PM
