Welcome back:
Since it didn't do this before, there is a chance you didn't gap the plugs in those cylinders properly or the plugs themselves are bad. However, my first suspect is that you bumped something while working on it and created a vacuum leak. It isn't hard to do. LOL
First, confirm that the air induction tube between the air box and the throttle body is properly installed and clamped, not allowing unmetered air to enter the engine. If that is good, you need to check if any vacuum hoses were damaged or disconnected. First, do a visual inspection. If they appear good, here is a link that will help you take it to the next step. Read through it before you begin. You will be using carb cleaner to check for leaks. Be careful not to spray it directly on anything that can be exceptionally hot like an exhaust manifold. And to be honest, and don't laugh, I always have a fire extinguisher near me when I do this test, but that's your call.
Do these things first because I suspect it is something simple like this.
Also, since there was a bad misfire prior to replacing the plugs, there is a chance the catalytic converter was damaged and is partially plugged causing this. Take a look through these links to see if anything mirrors the symptoms. Also, I will add a link that shows how to check a converter.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Let me know what you find.
Feb 17, 2019 at 5:06 PM
