I got my engine to start by using some starter fluid. It seams to run okay but when it warms up and give it gas it stalls out and then stops running. I try to restart the engine and will not start.
Would it be a vacuum issue? If it is where would that be. I have all the openings closed off I replace the old tubing's I do have one hose that I do not know were it goes and one sensor wire that I can not find were it goes either. If it is not a vacuum issue what else might it be?
Dec 9, 2018 at 3:49 PM
