The engine idles very hard in park but in drive it stalls, pop, and then cuts off what could cause this problem
Feb 22, 2016 at 11:29 AM
THIS IS MIKE
CERTIFIED EXPERT
Check your fuel pressure with a manual gauge on the Schrader valve (looks like a tire valve) located on the fuel rail, the fuel pressure should be between 45 - 60 PSI
