After driving twenty miles or so on the highway, the car will shut off, and sometimes it will start back up but sometimes it does not until cooling down. There are no codes coming up but PCM? The transmission will not go into gear until warming up as well, never had transmission problems before and the transmission is fine after warming up for a few minutes. I have had the position sensor replaced, rotor, spark plugs, wires, catalytic converter, 02 sensor, fuel pump, idle control motor, checked for vacuum leaks, water pump, and radiator replaced but still having the same problem. No service engine soon message, but I believe it was just cleared manually. There have been several PCMs changed from wrecking yards and Rock Auto. Any suggestions are deeply appreciated.
Nov 2, 2017 at 4:09 PM
