Engine stalling after oil change
2002 MAZDA DEMIO
65,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
ZELIGO
After changing engine oil the car started stalling when idle and driving and shifting gears randomly.What could be the cause?
Jun 17, 2020 at 11:39 AM
We don't have a manual on this vehicle as it is not offered in the USA so it is hard to know for sure due to not being able to see how the engine operates.
However the obvious things to check are oil levels and to make sure you have the correct filter installed.
The next thing we need to do is check oil pressure and see if it is dropping when this is going to stall. Clearly once the engine does stall it should drop but not before. Let us know what you find. Thanks
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Jun 17, 2020 at 1:21 PM
ZELIGO
can dirt/muddy oil crust on crankshaft sensor contribute to this matter?
Jun 18, 2020 at 2:30 PM
Absolutely. Here is a guide that runs through this but that is not going to be related to the oil change. More then likely it is just a coincidence.
Let us know what you find with this. Thanks
Jun 19, 2020 at 5:55 PM
