Engine cuts out without warning, then starts no problem. there is no codes showing up. any ideas what the problem could be? thanks.
Jan 9, 2020 at 4:37 AM
CERTIFIED EXPERT
This sounds like an issue with the crank sensor. This is required for the PCM to know where the position of the crankshaft is and if it doesn't have that, it will shut the engine down.
