Engine sputters and shuts off
2003 CHEVROLET VENTURE
200,000 MILES • 6 CYL • 2WD
ERIC REED
It runs engine gets warm it starts sputtering and start losing power, blows white and finally it quits running.
Jul 6, 2019 at 11:10 AM
STEVE W.
  • 15,113 POSTS
Welcome to 2CarPros. If you mean it is blowing white smoke out of the exhaust the most likely issue is a bad head gasket or failed intake gasket that is letting coolant into the engine. GM had issues with intake gaskets on some V6 engines over the years. Testing for a failed head gasket isn't hard and the tools are usually available as loaners from the parts store.
Try those and see if it shows as a bad head gasket. For the intake gasket it depends on which engine it is.
Jul 6, 2019 at 12:15 PM
