After starting it white smoke comes from tailpipe
1998 FORD F-150
170,000 MILES • 6.4L • V8 • 2WD • AUTOMATIC
AWAKE676
truck sat up for 2 years. after starting it white smoke comes from tailpipe with a strong fuel smell. no check engine, idles well. what could be happening?
Oct 25, 2019 at 9:13 AM
SCGRANTURISMO
  • 4,897 POSTS
Usually, white smoke coming from the exhaust means that coolant is being burnt in your vehicle's engines combustion chambers. The coolant can be getting introduced into the combustion chambers by a blown head gasket, a cracked cylinder head or engine block. On some vehicles with a coolant crossover tube the coolant can be leaking in via a failed gasket going into the cylinder head and down the valves. Here is a link below explaining it in greater details:
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
Please go through this guide and get back to us with what you are able to find out.
thanks,
Alex
2CarPros
Oct 25, 2019 at 10:27 AM
