engine is stalling and will restart when cooled off
1992 LEXUS SC 400
16,000 MILES • 4.0L • V8 • RWD • AUTOMATIC
CHUCKIE46
  • 6 POSTS
engine shuts off check engine comes on flickers and it shuts down after letting it sit for a while it starts up until it gets hot. I retrieved codes 42 and the next one is 26 ive pulled off the air box and seen one flap open and one closed
Jun 30, 2014 at 9:39 PM
HMAC300
  • 48,601 POSTS
for code 26 check fuel pressure with a gauge auto parts rent it. also check vacuum leaks.maybe reason one flap closed on airbox. code 42 is a vehicle speed sensor problem. have a pro check this because it has to be checked for a bad ecu
Jul 1, 2014 at 6:10 AM
CHUCKIE46
  • 6 POSTS
The car when you first start it it runs fine but once it warms up it starts acting crazy shuts off check engine light flickering it idles up and down sounds like it's starving for gas
Jul 1, 2014 at 1:53 PM
HMAC300
  • 48,601 POSTS
check your battery for condition including load test may be bad. autoparts do for free. make sure terminals are clean and all fuses are good. Otherwise let a pro look at it.
Jul 1, 2014 at 3:18 PM
