The engine starts well and runs good for ten to twenty minutes and then cuts off. It will not start for anywhere from forty five minutes to two hours. Fuel pressure at the fuel rail is 45-50 lbs. both when running and after the engine shuts off. A new fuel pump and filter were installed but did not fix the issue. I've been told the crankshaft position sensor could be at fault but I don't know how to check the resistance because of location and clearance issues. Please let me know what I am missing and/or how to test the sensor.
Jun 27, 2019 at 9:31 AM
