Engine shut-down
1997 INFINITI I30
94,600 MILES • 6 CYL • TURBO • 4WD • AUTOMATIC
CARLA AXELROD
  • 4 POSTS
Yesterday, while I was driving, I had stopped for a red light when my car's engine just shut off. I turned the ignition off and restarted it again and successfully made it home. Now I am afraid of this happening again. Is this significant of a major/minor problem?
Jan 14, 2018 at 1:24 PM
KHLOW2008
  • 41,814 POSTS
Since it had started right back, this should not be a major problem. It could be just that the idling speed was too low and the engine computer did not react fast enough to prevent the engine from stalling as you were stopped.
Try getting the air intake circuit cleaned, usually entails cleaning the idle air control valve and throttle body.
Jan 15, 2018 at 1:29 AM
CARLA AXELROD
  • 4 POSTS
Would you know an approximate cost to have someone do this for me? I do not think I would be able to do it myself. I also do not want to be taken advantage of by a mechanic, since I am not sure how much it would cost.
Jan 15, 2018 at 8:14 AM
CARLA AXELROD
  • 4 POSTS
I forgot to ask you this: How long would it take to do the cleaning of the idle air control valve and throttle body?
Jan 15, 2018 at 8:30 AM
CARLA AXELROD
  • 4 POSTS
Thank you for your help (I really needed it!).
Jan 15, 2018 at 8:31 AM
KHLOW2008
  • 41,814 POSTS
Sorry for the delay in replying.
The above mentioned job should not cost you more than an hour of labor charge.
Jan 15, 2018 at 7:59 PM
