Engine shaking
2010 CADILLAC SRX
104,000 MILES • 1.3L • V6 • TURBO • AUTOMATIC
ILOVELIFE@413
The engine is starting to rattle. And I just had a hub bearing put on. However, I have no lights indicating that something is wrong.
Jun 13, 2019 at 3:35 PM
Hi ILOVELIFE,
An engine rattle could be a number of different things. Can you give a little more detail about when it does this? Is it just a noise or does it run rough? Also, is it only while driving or sitting still?
I just am not sure the correlation between the hub bearing and an engine rattle so I need a little more info to go on.
If it is something that a video would demonstrate better, then feel free to get a video of it and post it so we can get on the same page. Thanks
Jun 13, 2019 at 4:43 PM
ILOVELIFE@413
It’s shaking while driving and at first there were no lights now I have a light.
Jun 13, 2019 at 5:05 PM
Okay. I suspect you have a misfire or a vacuum leak. We need to start with getting the codes that are there and are the reason for the light to be on.
If you don't have a scan tool that can pull the codes, most parts stores can pull them for you free of charge. If you can get me those, we can narrow this down.
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Jun 13, 2019 at 5:15 PM
