Engine runs fine when it is cold, but gets worse as it warms up
1989 VOLKSWAGEN GOLF
180,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
BARBARA907
  • 5 POSTS
We have done a lot of work to this car, including new transmission, coil, sparks plugs/wires, clutch, new swivel gasket. Now it runs fine when cold, but gets worse as it warms up--hesitating and eventually it just quits running. We have checked the timing and also run it with the 02 censor unhooked/hooked back up, and it makes no difference. Any ideas? Thanks!
Oct 19, 2015 at 12:57 PM
When warm and it stalls, does it start right back up?
Oct 19, 2015 at 6:29 PM
BARBARA907
  • 5 POSTS
Yes it starts fine. Today we checked the coolant temp sensor and the air temp sensor and they both seem okay too. Thanks!
Oct 19, 2015 at 7:22 PM
Since it starts right back up, chances are it is a sensor. The problem is, which one? Do you have access to a real time scanner that you can view data while the vehicle runs?
Oct 20, 2015 at 5:41 PM
Rewind... I forgot it is an 89. The scanner won't help. When it stalls, is it like shutting the key or does it slowly die?
Oct 20, 2015 at 5:42 PM
BARBARA907
  • 5 POSTS
I would say slowly dies. . . it just kind of gets coughier and more spluttery and then quits.
Oct 20, 2015 at 5:47 PM
What you described sounds like a fuel related issue. Have you checked fuel pressure or replaced the filter?
Oct 20, 2015 at 5:52 PM
BARBARA907
  • 5 POSTS
It runs great until the temp needle starts to move to the middle of the range. At that point, it starts to idle rough and will stall, but doesn't diesel. We haven't checked the fuel pressure, but we did replace the filter. Using a Robert Bentley service manual, we tested the digifant two module/connectors. We didn't get the right values for the ICU. The airflow sensor had 1 test that was good and 1 that was bad. We didn't really understand the testing process for the O2 sensor. We have gone through all the vacuum lines and we didn't replace them, but they look okay.
Oct 20, 2015 at 7:26 PM
If you can allow the vehicle to idle in the driveway till it warms up and dies, put a fuel pressure gauge on it and confirm it doesn't drop off. If it checks okay, the next focus area is the crank sensor.
Let me know what you find.
Oct 22, 2015 at 5:38 PM
BARBARA907
  • 5 POSTS
We tested the fuel pressure. It was 35 PSI when the car started, but as the engine warmed up, the fuel pressure dropped to 20PSI and the car started to run bad. After the car died, the fuel pressure dropped to 18.
Oct 31, 2015 at 1:05 PM
If the fuel filter has never been replaced, try that first. It is cheaper. If that doesn't help, most likely, the pump itself it bad.
Let me know if you have questions.
Nov 8, 2015 at 4:51 PM
