It has recently become very cold where I live. A month ago, I replaced the coolant temperature sensor in the 3.0 L V-6 VVT engine in my 2012 Equinox because it had failed. At first, it didn't work. But I took off the negative battery cable to reboot everything, and it worked!
About a week and a half ago, it got very cold out. When I drove the car, the temperature guage just barely moved up. The heater barely blew warm air, even after driving for 40 minutes.The faster I drove, and the more I turned the heater fan up, the more the temp guage went down to almost zero. This was new, it has never happened before.
It seemed very obvious that the thermostat was stuck open.I had it replaced, and on that day it was much warmer outside. The temp guage came up and there was hot air from the heater. I assumed the problem was fixed. Not so!
Today it was very cold again. I drove the car for half an hour, and it was doing exactly the same thing!
The controls for the heater all appear to be working properly.
The engine is running cold, even with a new thermostat.
What else could cause this? Is there perhaps an air block in the coolant after the repair? But it is doing exactly the same thing as before the repair!
Thank you in advance for your consideration and knowledge in this matter, Mike1961
Dec 22, 2025 at 12:25 AM
