engine running rough it only goes up to 4000 rpm
2009 DODGE CHARGER
83,000 MILES • 6.1L • V8 • RWD
RONYLOARCA
Driving home from work stoped for fuel filled the tank and got back on the highway . I notice a slight delay on the accelerator 10 miles out the engine light came on and the engine was stalling so I pulled over the next exit and the engine shuttle of ..towed the car home and hooked it up to a code reader and got p0221/ p0111 / p0340 / and it also showed ignition coils D.G miss fire.. so I changed the the coils and the throttle body installed new spark plugs and the camshaft position sensor the car runs better but still very roughly it won't go pas 3800 rpm and engine light is still on and the computer code still showing coil g still miss fireing . Any suggestions. ?
May 23, 2014 at 8:55 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuelpressure first autoparts rent gauge
May 23, 2014 at 9:29 AM
