engine running hot
2000 FORD EXPEDITION
210,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
RYANLEE
Started with heater core leaking in floor. I tried flushing cooling system. When I pulled drain plug on radiator, nothing came out. Put two 22oz bottles of Prestone flush+cleaner in to radiator. Drove it one hundred or so miles with drain plug out. I finally got a piece of 14 awg copper wire and dug it out till water started flowing. I bypassed heater core till I had time to replace. I replaced it finally and forgot what hose went where on core. "still not sure if they are right. I changed thermostat. It seems to me that the coolant just not flowing right. Can we start with the two hoses going to core?
Aug 7, 2016 at 9:07 AM
HMAC300
  • 48,601 POSTS
we do not have diagrams of heater hose connections, but normally one is smaller than other. try bleeding system as that may be the problem. start with a full degas bottle first. see picture for instructions.
Aug 7, 2016 at 12:12 PM
