The truck listed above is a 1500 z71. I put in drive and I believe noise is coming from transfer case but drive shaft not spinning. Could it be a bad Transfer Case, or could the flywheel be broken? I had that happen before and the truck didn’t move. Or could it be transmission? I used the truck all last week moving stuff from one storage unit to another, it ran fine. I get in it today go about a mile and it goes out.
My transfer case switch in cab of truck is stuck in neutral if transfer case is stuck in neutral is that y my driveshaft not turning? Could I take off the encoder motor and manually put in Drive?
Jul 6, 2022 at 1:17 PM
