Engine restricted cause of p0366 and p0016 camshaft and crankshaft correlation
2011 JAGUAR
24,000 MILES • 5.0L • V8 • RWD • AUTOMATIC
RUSSIA3488
I have a 2011 jaguar xjl with 24,000 miles. Starts and run ok except when idle, and I am getting 2 codes p0016 and p0366, I checked timing, chains and tensioner, replace cam sensors in bank 1 and crankshaft sensor. Codes are still there and restricted performance. What could possibly be wrong and how to fix it.
Dec 6, 2014 at 6:11 AM
HMAC300
  • 48,601 POSTS
on0016 the cam shaft timing plate may be screwed up or jumped due to a timing chain problem which you said you checked. see pic for code 0366, however a pro has to use his scanner to fix the correlation to adjust it after it's fixed. It may be a pcm problem as well.
Dec 6, 2014 at 7:14 AM
