I attempted to install underglow on my car and attach it to a fuse so I could control it from the cabin. This didn't work and it's now attached to the battery but while searching for a fuse we took many BCM fuses in and out.
Now, I am able to turn the key off and remove it and the engine continues running. On top of this, when the car is off there is a check engine light and when the car is on it tells me to service my airbag (even though they are fine). I assume its an electrical issue but I tested every BCM fuse and nothing was wrong with any of them. Currently, to turn the car off, I take out the fuel pump fuse.
Apr 6, 2021 at 10:29 AM
