engine rebuild: bearing and piston ring size
1982 FORD FUTURA
250,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
JKINARD
  • 47 POSTS
I am ordering an engine re-ring kit for a 1982 Ford Fairmont Futura and they are asking me for the sizes for the bearings and the piston rings. how do I know what size to order?
my options are:
connecting rod bearing:
0.010" undersize
0.020" undersize
0.030 undersize
and standard
piston ring:
0.030" oversize
0.040" oversize
0.060" oversize
crankshaft main bearing:
0.010" undersize
0.020" undersize
and standard
Oct 14, 2017 at 10:24 AM
MHPAUTOS
  • 31,937 POSTS
You need to measure the crank shaft big end and main journals with a micrometer, this is a precise measurement and cannot be guessed the rings are referring to bore size. this is also a precise measurement, and should be done by someone with expertise using precision measuring instruments.
Oct 14, 2017 at 7:13 PM
