Hello to all who read,
I'm in the process of engine swapping my truck from the v6 to the Magnum 318 v8 that also came out of another 1993 Dodge Dakota.
I am on the verge of having every essential item for my engine rebuild I am only missing a set of lifters and the v8 ecu for the build.
I have very little knowledge of the in's and out's of the motor except that everything on it appears to be Mopar genuine down to the plug wires and that its covered in years of dirt and oil and has absolutely no rust. So hopefully a good buy.
All I'm looking for now is good rebuild advice, I have new pistons, rings, engine bearings but if the engine internals are in good condition I'd like to go about doing the gaskets, oil pump, timing chain, water pumps, etc and a good painting. I have a few books describing the magnum rebuild and even performance stuff my biggest worry is making sure things go back together right such as torquing, making sure the engine is timed right, and which bolts to use thread locker on, what I should or shouldn't lubricate, etc.
Mainly I'd just like a professional opinion on how I should go about my build don't want to throw an engine in and have it explode or bend something due to my mistake.
Thanks to all who read or reply, have a wonderful day.
Jan 18, 2020 at 2:49 AM
