A crankshaft position sensor will cause ignition problems if it is failing. Do me a favor. Take a look through this link and let me know if you feel anything mirrors what you are experiencing:
Also, yes, the sensor or a connection at the crankshaft sensor can cause this. However, the one code that has my attention is related to the MAP sensor, code 14. On this vehicle, the barometric pressure sensor is integral to the PCME. When code 14 is set, the PCME itself is usually the problem and needs to be replaced. See pic below.
The PCME (powertrain control module) is located behind the passenger seat. I have a feeling this is where the problem is coming from. Interestingly, it can't be tested independently. That is where the manual says to replace the PCEM if code 14 is set.
Let me know your thoughts.
joe
Jan 23, 2024 at 7:47 PM
