Engine has no pressure
2005 KIA SORENTO
90,000 MILES • 2.4L • 4 CYL • 4WD • MANUAL
DEE OJ
The engine was once opened by the mechanics but now it has no pressure and makes some noise when on operations.
Apr 3, 2018 at 5:36 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
No pressure as in what, no cylinder compression?
Why did a mechanic once open the engine and what did he do in there?
What type of noise does it make now and when, at idle revving up, in gear, hot/cold, etc.?
Apr 3, 2018 at 6:36 AM
DEE OJ
the mechanic changed the oil pump, the shaft, grind the valve, replace the cap change the the top gasket.
Apr 3, 2018 at 8:45 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Why did a mechanic once open the engine?
What type of noise does it make now and when, at idle reving up, in gear, hot/cold, etc?
Apr 3, 2018 at 9:08 AM
DEE OJ
The engine do smoke, like burning oil and when you drive it the movement is retarded. the mechanic open it because it once had oil water mixed and crank shaft sensor error.
Apr 3, 2018 at 9:24 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Apr 3, 2018 at 10:57 AM
