When I step on the gas pedal there is no power at all?
2010 INFINITI G37
184,836 MILES • 1.7L • 6 CYL • 4WD • AUTOMATIC
MARIO HERNANDEZ2
Car starts and idles, when I step on the gas pedal and no power at all.
Mar 17, 2025 at 3:22 AM
This happens when one of the catalytic converters gets clogged, the engine has skipped time, or the MAP sensor or fuel pump is bad. Let's run the codes for clues of what the problem can be, so we can go from there. Here are two guides, please go over them and get back to me.
and
https://www.2carpros.com/articles/engine-has-low-power-output
You might what to use a rubber mallet and tap the exhaust system to see if you can hear anything rattling inside just behind the cats. Check out the images (below).
Mar 17, 2025 at 1:15 PM
