I have recently scanned my check light and to find P0014 and P0017 codes. I was driven to check after experiencing bad engine performance such as loss of power, intermittent squeaking noise, rough idle, stalling and the engine shutting off while stopped. There is also the presence of a tapping type of noise when the engine is running. I checked the oil level, which was low, and the oil was rather dark and thick, so I changed the oil, replaced the VVT solenoid and connector, with no noticeable improvements. Would this be an issue of the timing chain or maybe the camshaft actuators? I am attaching an audio file of the noises.
Apr 14, 2025 at 12:52 AM
