I have a strange issue with the coolant overheating. Once the engine reaches operating temperature, sitting at a stoplight causes over temperature warning. If I run the engine at a slightly higher RPMs (2,000-3,000 RPMs) the temperature drops down to normal which doesn't make sense. I would think higher RPMs would create more heat. I had to replace the engine due to being taken across by a Ford dealer in my area. The replacement engine had new water pump and timing belt.
Apr 3, 2022 at 7:15 AM
