Engine overheating
1996 PONTIAC FIREBIRD
66,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
MARCO HERRERA
The test analyzer says to replace the cooling fan motor relay, but there are three, should I replace the three?
May 11, 2019 at 12:13 PM
Good afternoon,
What tells you to replace the relay?
What code did you see for this?
Does the cooling fan work at all?
I attached a wiring diagram for you to view. Test for power to the relay on the red wires first to be sure there is power available.
May 11, 2019 at 12:47 PM
